Bulk Material Handling Group
  • 1.  Survey for PHD
    Posted 06-03-2026 03:34 AM
    Hello SME Community!
    I would greatly appreciate it if you could complete the survey below which will only take 10 minutes of your time and is completely anonymous. Now is the time to make your voice heard and reshape your work environment for the betterment of all.
    CONSTRUCTING A RETENTION FRAMEWORK FOR THE HYBRID ENGINEERING ENVIRONMENT: THE EFFECT OF ADAPTABILITY RESOURCES
    Solutionresearch remove preview
    Dear Engineer, You are hereby invited to participate in a research project. The aim of this research will be to investigate the relationship between career adaptability, grit, and positive coping in predicting employee retention to understand if a retention framework can be developed to direct retention management practices for the hybrid engineering environment in South Africa.
    View this on Solutionresearch >
    Thanking you in advance.
    Adrian Singh
    Gold Ore (Pty) Ltd
    Founder and CEO
    Inventor of the MACH Reactor
    ADRIAN Singh
    CEO and Founder
    Benoni South Africa
    27(82)9407057
