As everybody knows, there are over 280 billion tonnes of tailings around the world deposited in dams/deposits. In all types of tailings there is a percentage of one or several types of metal oxides ultra fine grains. In the pass, these ultra fines lost were assumed as a "cost of doing mining business". Well, the world went a radical change and losing ultra fines is not longer accepted as doing mining business. Society, Investors and Governments are demanding a more sustainable mining. Sustainability passes by recovering and not losing these ultra fine grains.
What was missing was a technology capable grasping these ultra fines and less problematic, what do do with these ultra fine grains.
Flotation, in real world operations, is very complex and it has a technical limitation to grasp grains smaller than 150 micros. Depending on the metal oxide, this translate into losses ranging from 20% up to 50% of the TOM in form of ultra fine grains.
We invented, developed and patented a new mineral separation process based on liquefaction effects. Liquefaction here is used as geotech (not physics) term. That is the effect that happens in saturated soils during an earthquake.
Our MVTs were made with zinc and iron tailings and with milled iron ore. Results can be seen here: SmartDry MVTs results and technical data.pdf
Zinc & iron ultra fine grains recovery from zinc tailing can be seen here: Rejeito ZINCO acelerado
| YouTube |
remove preview |
| Rejeito ZINCO acelerado |
| Zinc tailing undergoing zinc and iron ultra-fine grains recovery via liquefaction. The video is edit, so it jumps in time to show the vital, critical phases. The time frame is not real, recovery of ultra-fine grains varies according to the material characteristics, level of "dirtiness", among other factors. |
| View this on YouTube > |
Iron ultra fine grains recovery from zinc tailing can be seen here: Liquefação do Rejeito Mineração Ferro
We are looking for strategic mining partners to create joint ventures to mine tailings or license our technology.
Cheers,
FERNANDO BERLINCK DUTRA VAZ
CEO
Recife PE Brazil
550819 -99999113
